PTGen-Window stealing window focus
  • solarjoe
  • Senior Member
  • Senior Member
06 Dec 2012 07:31 #1061 by solarjoe
PTGen-Window stealing window focus was created by solarjoe
I have another question and hope that you can help me.
During parametric runs the PTGen Optimization window
is always stealing the window focus, which is slightly annoying :)
Is there a way to prevent this?
Kind regards,
Joe
  • Paul Gilman's Avatar
06 Dec 2012 16:49 #1062 by Paul Gilman
Replied by Paul Gilman on topic PTGen-Window stealing window focus
Hi Joe,
As you observed, when you run PTGen from a SamUL script using the PtOptimize() function, the Command window takes focus for the few seconds that PTGen is running and displays itself on top of other windows that are open on your desktop.
That can be annoying if your script takes a long time to run and you want to use other programs on your computer while it is running.
For now, there is not a way to change this behavior.
  • solarjoe
  • Senior Member
  • Senior Member
10 Dec 2012 09:49 #1063 by solarjoe
Replied by solarjoe on topic PTGen-Window stealing window focus
Hello Paul,
ok, thanks for your quick reply.
Yes, my scripts take quite a long time, as I am running
parametric calculations of 2 variables on Solar Tower plants.
Maybe a solution could be provided sometime.
Kind regards,
Joe
  • solarjoe
  • Senior Member
  • Senior Member
18 Dec 2012 14:00 #1064 by solarjoe
just one more comment on this:
I banished SAM into my virtual machine ( www.virtualbox.org ), so far
this works like a charm and I can minimize it :)
Kind regards,
Joe
