Can SAM model industrial process steam generation from solar thermal technologies? It appears that the Concentrating Solar Power models focus on electricity generation and the Solar Water Heating models are geared toward relatively low temperature domestic hot water. However, it would seem as though the Concentrating Solar Power models could be used to determine collector field heat output which could be used to estimate industrial process steam generation. Alternatively, an equivalency factor could be used to convert kWh back to steam generation in mmBtu. Is this possible?
