HELP DESIGN 2 PLANT CSP
  • YASNA
  • New Member
  • New Member
05 Dec 2019 18:30 #7825 by YASNA
HELP DESIGN 2 PLANT CSP was created by YASNA
I am developing two cases of solar tower central simulation with molten salts. The first case is to design the entire plant and the second case is to design two smaller plants that meet the total energy requirement. When I design the smallest plant, it gives me higher tower values and number of heliostats. Help I don't understand why this happens.  Im put the same MS and the same full load of storage. Honestly i no have idea if this is the problem. HELP
  • Paul Gilman's Avatar
05 Dec 2019 21:08 #7826 by Paul Gilman
Replied by Paul Gilman on topic HELP DESIGN 2 PLANT CSP
Dear Yasna,
Can you send me a copy of the .sam file or files that show these results?
  • YASNA
  • New Member
  • New Member
08 Dec 2019 01:38 #7829 by YASNA
Replied by YASNA on topic HELP DESIGN 2 PLANT CSP
File Attachment:
File Name: OPCIONbATACAMA.sam
File Size:289 KB
File Attachment:
File Name: OPCIONAATACAMA.sam
File Size:214 KB
File Attachment:
File Size:289 KB
File Attachment:
File Size:214 KB
File Attachment:
File Name: OPCIONcATACAMA.sam
File Size:247 KB
undefined
09 Dec 2019 23:19 - 11 Dec 2019 17:25 #7834 by Paul Gilman
Thank you for sending the files.
In the attached file, I imported the Option b and Option c cases into the Option A file so that it is easier to compare the different cases. Note that I changed the weather file to Daggett, California. You should change it back to your weather file.
Please use the "Inputs browser" on the File menu to see a list of inputs that have different values in the three cases. You can see that in addition to a different nominal capacity (design turbine gross output), there are other parameters that are different such as the solar multiple, receiver dimensions, etc. You can change the input variable values in the inputs browser table to make the cases more consistent.
Also, after you change the input parameters, be sure to generate a new heliostat layout and optimize the layout for each case to see what the resulting tower height and number of heliostats is.
Last edit: 11 Dec 2019 17:25 by Paul Gilman.
  • YASNA
  • New Member
  • New Member
10 Dec 2019 22:42 #7838 by YASNA
If my 9100 MW consumption plant has 10 hours of storage, the 4550 should be half the time?
The solar multiple would change for each one?
help
06 Jan 2020 17:47 #7857 by Paul Gilman
The solar multiple is an input. You will have to determine the optimal value of the solar multiple that results in a solar field that can both drive the power cycle and meet the storage requirements.
