Note pad in SAM
  • Ben
  • New Member
  • New Member
12 Nov 2019 14:45 #7782 by Ben
Note pad in SAM was created by Ben
Good day,
How do I permanently remove the note pad in SAM after using it. It pops  up every  time I start SAM
  • Paul Gilman's Avatar
13 Nov 2019 16:06 #7789 by Paul Gilman
Replied by Paul Gilman on topic Note pad in SAM
Hi Ben,
The Notes window will disappear when it is empty. There is probably a space or tab in the window that you cannot see. Select everything in the window (ctrl-a), delete it (ctrl-x), and then close the window using the 'X" at the top right corner or navigate to another page and back.
You can find instructions for this and other similar tasks in the Reference section of SAM's Help system.
