Notice that the SolarEdge Technologies Ltd : SE100KUS [480V] is showing a max AC output of 33300 Wac when it should be 100000 Wac as this is their 100k invert model (if I am reading it correctly).
If you find this in is fact the case, what is a possible workaround until it is updated across all of SAM.
The data in SAM's inverter library comes from the spreadsheets posted at
www.gosolarcalifornia.ca.gov/equipment/inverters.php
. We update the library with each release of SAM. The next release is scheduled for later this year.
To model an inverter that is not in the library, or to use different specifications for a one that is in the library, you can use the technique described in this post:
