Combine Cases financial results are zero?
  • Mahamoud Mayoo
  • New Member
  • New Member
02 Sep 2021 05:32 #10028 by Mahamoud Mayoo
Replied by Mahamoud Mayoo on topic Combine Cases financial results are zero?
Good morning!
i mew in the forum. i want to simulate hybrid PV / CSP system in SAM, but combining cases in macro does not work, there is always an error message. I do all the combinations of the different models but still no solution. I am using SAM 2020.11.29. I would like to know if it's possible to manually calculate the capacity factor of the hybrid configuration power plant using that of PV and CSP.
best regards
  • Paul Gilman's Avatar
07 Sep 2021 23:30 #10039 by Paul Gilman
Replied by Paul Gilman on topic Combine Cases financial results are zero?
Hi Mahamoud,
Please try the workaround solution described in this GitHub issue:
github.com/NREL/SAM/issues/282
