solar hot water
  • nk
  • New Member
  • New Member
20 Jun 2018 10:22 #6297 by nk
solar hot water was created by nk
while designing solar hot water, total system flow rate as mentioned in help is the flow rate for the collector side. so how is the tank side flow rate taken care of? and also the pump is mentioned generally. the pump refers to the collector side or tank side? Also, in cases where load exchanges heat through exchanger and actually the tank side water is not used up ie only the energy is used up. so how then is tank temperature calculation affected? thanks in advance.
  • Paul Gilman's Avatar
28 Jun 2018 15:41 #6298 by Paul Gilman
Replied by Paul Gilman on topic solar hot water
Please see the description of the solar water heating model in SAM's help system (click "Solar Water Heating" in the table of contents). It includes a diagram showing the location of the heat exchanger and pumps, and where in the system the flow rates are calculated.
