Hi ,
I generate code pyton with SAM, but doesn''t work when I execude a code.
syntax error (ssc.data_set_matrix( data, b'subarray1_shading:mxh', subarray1_shading:mxh );
Could you attach the .sam file you used to generate the Python code to your original post above (edit the post to attach another file). It looks like there might be too many spaces in the subarray_shading:mxh arrays.
