Trackers of HCPV
  • Princess_Zaynab
  • New Member
  • New Member
23 Feb 2018 17:19 #6069 by Princess_Zaynab
Trackers of HCPV was created by Princess_Zaynab
Hello Paul,
Please I want to have more explications about trackers in HCPV simulations:
Tracker elevation limits (deg) min max
Tracker azimuth limits (deg) min max
If I put
Tracker elevation limits (deg) min 0 max 0
Tracker azimuth limits (deg) min 50 max 310
I will be modelizing only one tracker?
Can I put what I want in the values min and max?
Thanks in advance,
Zaynab
  • Paul Gilman's Avatar
26 Feb 2018 17:57 #6070 by Paul Gilman
Replied by Paul Gilman on topic Trackers of HCPV
Dear Zaynab,
If you want to model a single tracker, you should use the "Number of trackers" input on the Array page, and set it to 1 for a single tracker.
The angle limits determine how far the tracker is allowed to rotate. You can use the default values unless you have a reason to change them. For the "tracker elevation angle limits" input, you should use values between 0 and 90 degrees.
