Error Message in SAM PV (Detailed)
  • lwkerber
  • New Member
  • New Member
09 Sep 2016 10:03 #4754 by lwkerber
Error Message in SAM PV (Detailed) was created by lwkerber
I was able to use weather data with a 15-minute demand load input file using PV (PVWatts) version. But, using the same weather and demand input load using PV (Detailed), I get this message:
exec fail(pvsamv1): electric load profile must have same number of values as weather file, or 8760
Simulation pvsamv1 failed.
*** I found a similar issue issue/response after doing a search. So, instead of responding about using the LK script to adjust the weather data to 15-minute intervals, I will suggest an enhancement to provide a checkbox for SAM to do this for the user. It seems to me to be something that many others will encounter so having a simpler solution would be very helpful.
  • Paul Gilman's Avatar
12 Sep 2016 21:36 #4755 by Paul Gilman
Replied by Paul Gilman on topic Error Message in SAM PV (Detailed)
Thank you for that feedback. I will pass it on to the development team.
