enter POA data in weather file
  • Koen
22 Aug 2016 14:27 #4693 by Koen
enter POA data in weather file was created by Koen
I have been trying to sort out how to enter POA data into a weather file. I have pyranometer measurements in the plane of array.
Following the Help embedded in SAM and some helpful discussions on the forum, unfortunately I still can't get it to work. Somehow my conversion skill does not satisfy SAM :)
I tried a couple of things: in "USA AK Adak Nas (TMY3) 1.csv" I only copied the TMY3 file from the SAM directory to my custom directory and changed nothing, this works fine. But with "USA AK Adak Nas poa 2.csv" the only thing I changed is the column header from DHI to POA.
Somehow SAM thinks the format of the file has changed, since it does not recognize it anymore. Adding my custom dir to the resource library it gives funny data in the file listing (see screenshot). The checker macro returns an error: "could not determine the number of records in CSV weather file". When I try to select the file from the list, SAM runs in an endless loop. Could you please tell me what's going on? I'm running SAM 2016.3.14
Hope you can help.
best regards,
Koen
23 Aug 2016 16:59 #4694 by Paul Gilman
Replied by Paul Gilman on topic enter POA data in weather file
Dear Koen,
The problem with the #2 file is that the line endings are CR (carriage return), which SAM does not recognize. SAM requires line endings to be either CRLF (carriage return/line feed) or LF (line feed). See this post for more details:
sam.nrel.gov/node/69915
  • Koen
24 Aug 2016 02:21 #4695 by Koen
Replied by Koen on topic enter POA data in weather file
Hello Paul,
thanks very much, now SAM accepts the file! I use excel on Mac, and saved it as Windows csv. Sorry I overlooked that post on the forum.
Unfortunately SAM does not use the POA data yet. If I replace the GHI, DNI and DHI columns with one column with heading POA, the simulation returns an error "invalid beam irradiance nan W/m2 at time [y:1998 m:1 d:1 h:0], exiting
Simulation pvsamv1 failed."
I have tried putting the GHI, DNI and DHI back in, setting to Nan, 0 and keeping the values. Only the last option runs OK, but then the POA data are not used.
The file checker macro tells me to have at least two irradiance components, but POA is the only one that's relevant in my case.
Can you tell me how to construct the csv such that SAM uses the POA data?
thanks,
Koen
  • Koen
25 Aug 2016 09:38 #4696 by Koen
Just wanted to let you know I solved my issue. thanks for helping.
  • Koen
25 Aug 2016 09:42 #4697 by Koen
I (finally) succeeded in getting it to run. With the kind help of Paul and another forum member.
This is what I did and some additional tricks for people that are new to SAM or haven't got enough patience:
Whenever is referred to SAM help, you want to look in the help embedded in SAM. In the top right corner of the GUI, you'll find a tiny help button. It solves most of the problems. Do NOT search online it is not up to date.
most of the files listed in the solar source database, if not all, are in SAM csv format, contain three header lines:
Source,Location ID,City,State,Country,Latitude,Longitude,Time Zone,Elevation
TMY3,704540,Adak Nas,AK,USA,51.883,-176.65,-10,5
Year,Month,Day,Hour,GHI,DNI,DHI,Tdry,Tdew,RH,Pres,Wspd,Wdir,Albedo
and then the data
Usually these files contain GHI, DNI and DHI. To get POA in there, you either replace one of those columns or add a column headed with POA
Make sure you save the csv with the correct end of line character. Especially excel on Mac: save it as windows csv file. You'll need the CRLF (carriage return/line feed) or LF (line feed).
In the "Location and Resource" screen add the location of the csv file to the solar resource database (folder settings...) OR check the box below "Use a specific file on disk" and select your file with POA data
At the bottom of the "Location and Resource" screen expand the "Albedo - Sky Diffuse Model - Irradiance Data (Advanced) menu and check the box with POA data (either from reference PV cell, or Pyranometer)
This worked for me. I hope this post will help other people as well.
cheers,
Koen
29 Aug 2016 14:40 #4698 by Paul Gilman
Thank you for posting that detailed and useful information.
