Dear Suzan,
The biomass power model requires a weather file with global horizontal solar radiation data, and the Cairo weather file in SAM's library does not include that data. If you do not have access to a different weather file, you might try one with a similar latitude to Cairo that does include the global horizontal data, for example, you could use the weather file for San Antontio, TX.
The biopower model uses data in the weather file to calculate moisture in the feedstock, and also to calculate thermal losses in the power plant.
I will investigate the role of global horizontal data, and let you know what I find.
